Guest davidjones293 Posted September 11, 2016 Share Posted September 11, 2016 hi I have just got a 1998 1.8 ghia that would not start I have changed the fuel pump still no power to pump then it started run for about 30 mins then stopped left a while power back at pump stopped again have no power going to pump again can anyone help please Link to comment Share on other sites More sharing options...
Ian71 Posted September 11, 2016 Share Posted September 11, 2016 Sounds like a bad earth or cable has a fault somewhere . Good luck. Link to comment Share on other sites More sharing options...
Guest davidjones293 Posted September 11, 2016 Share Posted September 11, 2016 would that just take the pump out as everything else still works Link to comment Share on other sites More sharing options...
Ian71 Posted September 11, 2016 Share Posted September 11, 2016 My mk5 in tank pump packed up,turned out to be an earth wire on the side of the car floor just behind the drivers seat on inside of the sill. Very close to the lower drivers seat belt fixing Link to comment Share on other sites More sharing options...
Guest davidjones293 Posted September 12, 2016 Share Posted September 12, 2016 thanks for your help will have to check this out Link to comment Share on other sites More sharing options...
