Mk3 Standard Suspension
Guest Glenn65
Guest Glenn65
Ok folks, I fitted Spax adjustables last summer, but with my street being full of speed humps, I want to put my car back to standard ride height.
It's a basic GL, NOT XR or injection, does anyone know where I can source standard springs and shocks for it
Guest nicholas huntley
Just discovered something, if you need to replace front lower suspension arms, throw your Haynes manual into the bottom drawer! First side I did as recommended, took over an hour. Other side, drive car one side up on the curb, other side drive onto builders concrete block or similar so that car is level side to side. Take out two bolts then ball joint at wheel end. Pull out the worn arm, replace with a new one. Tighten everything up. All done and dusted, 20 to 25 mins!
You might email www.motorparts.ie and enquire about the shocks/springs you need, they are very helpful.
Good Luck,
Nick.
Guest Glenn65
Tried them and unfortunately they can't source anything :sad:
Does anyone know if mk4 springs or shocks/struts fit the mk3
