Guest Nelly Rs Posted July 26, 2015 Share Posted July 26, 2015 Hello I'm going to fit a new alarm to my mk4 where do I connect the central locking wires to ? Any help would be really appreciated , thanks in advance Neil :-) Quote Link to comment Share on other sites More sharing options...
Guest chris_g99 Posted August 4, 2015 Share Posted August 4, 2015 I did mine a long time ago now, but if memory serves me correctly i tapped into the loom inside the passenger side door. Quote Link to comment Share on other sites More sharing options...
Guest Nelly Rs Posted August 4, 2015 Share Posted August 4, 2015 (edited) Right bit of an update, tapped into the passenger side CL loom but it unlocks on arming and locks on disarm !! I've used white and yellow in the loom and swapped the wires from the alarm around as well with the same result ..... Now i'm stumped Edited August 4, 2015 by Nelly Rs Quote Link to comment Share on other sites More sharing options...
welshlad Posted August 5, 2015 Share Posted August 5, 2015 Are you using two wires or one ? Quote Link to comment Share on other sites More sharing options...
Guest Nelly Rs Posted August 5, 2015 Share Posted August 5, 2015 Two wires one lock the other unlock Quote Link to comment Share on other sites More sharing options...
Guest Nelly Rs Posted August 20, 2015 Share Posted August 20, 2015 (edited) Sorted this now . For future reference it's a negative cdl system yellow wire in the cl loom to lock and white to unlock, it was the passenger door lock not in the central position causing the fault I had ;-) Edited August 20, 2015 by Nelly Rs Quote Link to comment Share on other sites More sharing options...
