Sign in to follow this
Guest Joe35
Changing Roofs
Guest Joe35
Are the manual and electric hoods the same frame so it's a straight swap?
Share this post
Link to post
Hi Joe
From your Avatar I assume u mean a Mk4
Yes Manual Can b converted to Electric Roof
Share this post
Link to post
Guest Joe35
Thanks for answer, so if I got a manual frame would it be as easy to attach the electric connections on the manual frame?
Share this post
Link to post
yes you just need to swap the rams and locating pins over and take off the locking catches then wire in the pump and switch
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
