Guest tazanddave Posted April 22, 2013 Share Posted April 22, 2013 I have a loud knocking and grinding noise coming from the front n/s wheel especially when turning right and on near full lock. Can anyone please advice me wot this is and is it an expensive repair. Thanks. Quote Link to comment Share on other sites More sharing options...
gingergman Posted April 22, 2013 Share Posted April 22, 2013 possibly driveshaft? Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted April 22, 2013 Share Posted April 22, 2013 Drive shaft would be a clicking. Check the wheel bearing as the when you turn it will put more or less pressure on one side depending on which way you are turning. The fact you are getting a grinding sounds indicates bearing over bottom ball joint. What is the steering like? Do ou have any play? If so check the track rod end as well Quote Link to comment Share on other sites More sharing options...
escortrs2000.co.uk Posted April 22, 2013 Share Posted April 22, 2013 I'm going to say CV joint and wheel bearing. Remove the hub yourself, take it to a garage and get a new bearing fitted. Go from there, shouldn't be too pricy if you remove the hub yourself. Lee Quote Link to comment Share on other sites More sharing options...
Guest tazanddave Posted April 22, 2013 Share Posted April 22, 2013 No play in the steering and and grinding sound when driving normally.Hoping its not driveshaft as i hear they r expensive to repair or replace. Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted April 22, 2013 Share Posted April 22, 2013 Sounds like a wheel bearing to me Quote Link to comment Share on other sites More sharing options...
gingergman Posted April 22, 2013 Share Posted April 22, 2013 If it is wheel bearing and its grinding id get it changed asap changed before it collapses Quote Link to comment Share on other sites More sharing options...
gingergman Posted April 22, 2013 Share Posted April 22, 2013 As they normally whine Quote Link to comment Share on other sites More sharing options...
Guest tazanddave Posted April 22, 2013 Share Posted April 22, 2013 its not moved since ginger and ive booked it in at garage bout a mile away,bearings off e-bay.Thanks for your help folks Quote Link to comment Share on other sites More sharing options...
