Steering Problem
Guest tazanddave
Guest tazanddave
I have a loud knocking and grinding noise coming from the front n/s wheel especially when turning right and on near full lock.
Can anyone please advice me wot this is and is it an expensive repair.
Thanks.
Guest s6boy1979
Drive shaft would be a clicking. Check the wheel bearing as the when you turn it will put more or less pressure on one side depending on which way you are turning. The fact you are getting a grinding sounds indicates bearing over bottom ball joint. What is the steering like? Do ou have any play? If so check the track rod end as well
Guest tazanddave
No play in the steering and and grinding sound when driving normally.Hoping its not driveshaft as i hear they r expensive to repair or replace.
Guest tazanddave
its not moved since ginger and ive booked it in at garage bout a mile away,bearings off e-bay.Thanks for your help folks
