1992 Escort Xr3I Cabriolet Stereo Not Responding
Guest vanbasten
Guest vanbasten
HI guys, first post on here and am hoping for some help.
I have recently purchased a 1992 Escort XR3i cabriolet to restore and get back on the road.
However when bringing it home i've noticed that the Ford Sound 2000 radio is flashing "E E" in the display when turned on.
Does this mean it has been "locked out" or can it be reset again. I have removed it from the dash and there is no 3 or 4 digit security code on it.
Thanks in advance
Guest Craig2143
I would say that it has been locked then, you could always try checking the cables in the back and make sure there is not a loose connection, that could be causing the problem
  • 3 weeks later...
Guest ben smith
they are cheap to get uncoded from ford i have had a couple of ford 2000 series sterios that have had E E on the front
