Guest eve1973 Posted March 7, 2012 Share Posted March 7, 2012 Hi, I have a Escort XR3i cabriolet 1992 I have tried to open the bonnet on my car, but the cable is loose so has either snapped or come unclipped. I have read on forums about going under the car and releasing it that way, but I've gone under mine and you can't get to it as the part where the ford badge is, goes right near the radiator so can't get anything up to push on the latch. I can see where the latch is, that comes out when u pull the release cable through the gap under the bonnet, is it this part I have to move? If so is it left, right, up or down? If not can you tell me which part and if I can't get to it, what are my other options. Many thanks Eve Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted March 7, 2012 Admin Share Posted March 7, 2012 I had the same thing on my MK4, the only way i could do it was as you mentioned and ripped my hands and arms to bits in the process. Not easy but can be done. Quote Link to comment Share on other sites More sharing options...
Guest Steve Posted March 7, 2012 Share Posted March 7, 2012 Yep me too only way is down on the deck and rip your arms to bits lol best to do it when engine is cold to as I found out ouch!!!! Quote Link to comment Share on other sites More sharing options...
Guest eve1973 Posted March 7, 2012 Share Posted March 7, 2012 I was thinking of getting some thin rope and hooking on the lever and pulling it, is this not the lever I need to pull? Quote Link to comment Share on other sites More sharing options...
Guest Steve Posted March 7, 2012 Share Posted March 7, 2012 On my mk 4 I had to get to the latch that holds the bonnet down not sure on the mk 5 but I would imagine its the same it's hard and you can't see what your doin but just keep trying you will get it Quote Link to comment Share on other sites More sharing options...
maido Posted March 7, 2012 Share Posted March 7, 2012 the latch moves sideways not down well it did on mine lol, then when its open if bonnet cable is stretched just bend it over and cable tie it Quote Link to comment Share on other sites More sharing options...
welshlad Posted March 7, 2012 Share Posted March 7, 2012 if its just a unclipped cable and the tension has made it slack then undo the bonnet release latch inside the car and use a pair of pliers on the cable Quote Link to comment Share on other sites More sharing options...
Guest El87cabi Posted March 12, 2012 Share Posted March 12, 2012 it also helps to get someone to press down on the bonnet when you come to releasing the latch, good luck Quote Link to comment Share on other sites More sharing options...
Guest moondancer Posted August 5, 2015 Share Posted August 5, 2015 Tried to get under the jacked up car escort xr3i 1989 , does the catch go sideways , right or left to open ?? Quote Link to comment Share on other sites More sharing options...
