Guest bobatporty Posted January 5, 2011 Share Posted January 5, 2011 I have got a fault code 0209 which says there is a fault with the injector on No9 cylinder. but I have only 4 cylinders, am i missing something apart from 5 more cylinders Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted January 5, 2011 Share Posted January 5, 2011 Need to know your car make and model before anyone can help Quote Link to comment Share on other sites More sharing options...
Guest bobatporty Posted January 5, 2011 Share Posted January 5, 2011 Need to know your car make and model before anyone can help Mk3 mondeo I was just looking at fault codes as the fuel pump/sender unit not working and this was up on the dash display Quote Link to comment Share on other sites More sharing options...
Chris Posted January 5, 2011 Share Posted January 5, 2011 (edited) Sounds to me like an injector seals gone.. 02o' tend to mean fuel system.. does the car run? Edit that as read above.. Edited January 5, 2011 by Chris Quote Link to comment Share on other sites More sharing options...
Guest bobatporty Posted January 6, 2011 Share Posted January 6, 2011 Sounds to me like an injector seals gone.. 02o' tend to mean fuel system.. does the car run? Edit that as read above.. It ran Ok when driven sensibly when I bought it but when booted it would go in limp mode. On poking about I found the EGR valve and intake manifold was chocked up with carbon and one of the manifold seals was split and someone had botched the intercooler/EGR hose, making a much smaller diameter. After cleaning and replacing hose The car wouldnt start I quess its the fuel pump sender unit buggered as the pump dosn't run when the ignition is turned on, so just waiting for a new unit to arrive. The fault code would have been up before I did any work on it. Just wondering why it states cylinder #9 when it only has 4 cylinders Quote Link to comment Share on other sites More sharing options...
Chris Posted January 6, 2011 Share Posted January 6, 2011 P0209 Injector Circuit Malfunction ... sounds like you've either got an injector gone down or the seals leaking Quote Link to comment Share on other sites More sharing options...
Guest bobatporty Posted January 6, 2011 Share Posted January 6, 2011 P0209 Injector Circuit Malfunction ... sounds like you've either got an injector gone down or the seals leaking Ah well will get it running first then see how it go's. There was so many little faults on it am supprised it ran at all. But I got a 04 plate mondeo Ghia for £800 it'll be a real nice car when running right. Quote Link to comment Share on other sites More sharing options...
