New Cabbie
Guest John
  • Replies 248
  • Created
  • Last Reply
Top Posters In This Topic
no mate been buying single rims off ebay all but 1(but has a new tyre on it lol) are in really good conditiond never been sprayed still matt grey on the rear face.
very happy with the wing lines just need the doors off to spot the hinge side & bottom they are just single spotted at moment..
getting there :banana_dance: :banana_dance:
  • 2 weeks later...
well shes getting ready for some more work at weekend
floor looks good from this side
spare wheel tub ready for welding in
  • 2 weeks later...
  • 1 month later...
Guest John
Its been a while due to work but had hour on her last nite n 1hr tontie small repairs needed on front panel that no one will see
Guest John
had another fe hrs on her tonite
passanger sill looked ok but a little tin worm was cut out & welded up
stone guarded n primed
black stone guarded to finish
Guest John
cheeky hrs here n there seem to be the normal on these light nites
drivers sill was ok 2 small bits of tin worm cut out n fresh metal welded in. also where the new back arch meets the sill
after
stone chipped & primed.
hoping to get the spare wheel tube in this weekend
  • 3 months later...
had another cheeky hour while the boss was out lol
gonna cut this out big enough to get the new filler neck on then weld a new peice over it.
fingers crossed
well its worth giving the wife £150 for a weekend away didn't do anything i set out to do but after along time without being touched project got some work done.
my welder turned up to do a little bit.
Understatement for sure.
all project needs now is spare wheel tub welded in & drivers wing secured down A post. all welding complete.
Just secured storage for the all white for 5 months if needed so getting her shipped out then strip all underneath n paint.
heres the finished filler neck from back
from front
deffo been worth it for sure well happy :smile:
  • 2 weeks later...
this it coming along wicked top job
10/10 with the filler neck looks top
you will have to send the Mrs out more it might cost you :ohmy: but in the long run you can get lots done to this and the White 1 :laugh: :lol:
well another busy afternoon
got some goodies for the project
they need a little bit of TLC but in good condition
got them rubbed down & prepared ready for some high build primer
also got the last bit of welding done tonite
before
sill ends
during
Will get the grinder out tomorrow to dress the weld & prime it up.
car is now solid no rot on her.
Roll on the next step of the restoration
