Guest s6boy1979 Posted April 12, 2010 Share Posted April 12, 2010 Can someone help me please? Can anyone tell what hydraulic fluid to use for my roof and where can i get it!!!! Quote Link to comment Share on other sites More sharing options...
Guest richie29gt Posted April 12, 2010 Share Posted April 12, 2010 u can uses automatic transmission fluid Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted April 12, 2010 Share Posted April 12, 2010 Ok cool cheers Quote Link to comment Share on other sites More sharing options...
Guest dinky Posted April 13, 2010 Share Posted April 13, 2010 hello m8 i use hydraulic jack fulid £4 halfords it works perfect Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted April 13, 2010 Share Posted April 13, 2010 I used power steering fluid in mine when i converted to an electric roof. Not sure if its best but its been working perfect for the past 3 years. Quote Link to comment Share on other sites More sharing options...
Guest Pierce Posted June 7, 2010 Share Posted June 7, 2010 the fluid is green does anyone know if its the same as citroen suspension fluid Quote Link to comment Share on other sites More sharing options...
gingergman Posted June 7, 2010 Share Posted June 7, 2010 it would prob work mate, its all hydraulic fluid at the end of the day, plus if power steering fluid works lol . . Quote Link to comment Share on other sites More sharing options...
Guest Pierce Posted June 7, 2010 Share Posted June 7, 2010 I've found out what the oil should be by looking on jaguar forums as the pump in a old XK is the same the oil used should be Pentosin CHF 11S Quote Link to comment Share on other sites More sharing options...
Kim Booth Posted June 26, 2021 Share Posted June 26, 2021 On 13/04/2010 at 14:00, Guest dinky said: hello m8 i use hydraulic jack fulid £4 halfords it works perfect Hello, Yesterday I posted this question but I've just come across your comment from 10 years ago, do you think the same would work for me? Thank you. Transmission Fluid for Electric Roof no longer exists, what can I use instead? Kim Booth posted a topic in Roof Problems I have a 1987 Escort Cabriolet Ghia which needs me top up the transmission fluid for the electric roof to operate. The manual tells me I need to use part number 1661100 however that part number no longer exists, and Ford's parts department cannot suggest any other fluid I can use instead. Does anyone have any idea what I can use instead? Sorry this is the 2nd time for me to post this question but I cannot find my original question on ths site... 17 hours ago Quote Link to comment Share on other sites More sharing options...
Vincygav Posted August 4, 2021 Share Posted August 4, 2021 It is in the Haynes, sure it has been posted here many times before and able to find by doing search. IIRC It was Esso UNIV or some similar name. Other alternatives are from Morris oils and Millers Oils. It is green and a Citreon type fluid. I would not use other fluids mentioned above as they can damage some seals or encourage erosion of some internal parts. Quote Link to comment Share on other sites More sharing options...
