Guest Alex48 Posted February 8, 2010 Share Posted February 8, 2010 hey all, i'm not actually a new user i've just forgotten my username/password i think my user used to be alex-r but not too sure.. anyway, i still have the RS T Cabby, unfortunately the fuel pump went a couple of months ago, been sorted a while but in the time it took to fix i managed to loose the keys, i have 2 spares for the doors and boot, but have lost the filler cap and ignition keys. i've seen a cheap lockable fuel cap with keys on ebay for under a tenner and i've sourced an ignition barrel nearby too! what i was wanting to know is, what can i do about the steering lock? i've never done this sort of this before so i'd love to have a heads up before starting, any help would be great, cheers guys! Alex Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 8, 2010 Share Posted February 8, 2010 im not too sure but if you replace the barrel as your doing, wont it just unlock when you use the new key as you would the old? cos if it diddnt then you would always have the problem? Quote Link to comment Share on other sites More sharing options...
LeeMcCarthy Posted February 8, 2010 Share Posted February 8, 2010 yeah im sure its just the barrel that locks the steering so you should have no problem Quote Link to comment Share on other sites More sharing options...
Guest Alex48 Posted February 8, 2010 Share Posted February 8, 2010 ah great, hope yous are right, cheers! Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted February 9, 2010 Share Posted February 9, 2010 Hi Alex you might find the ignition lock has to be turned to pos 1 and on top of ingnition casing there is a hole you have to push something thin down to push pin in to release ignition barrel...other than that you need the casing as well....hope this helps Quote Link to comment Share on other sites More sharing options...
Guest Alex48 Posted February 10, 2010 Share Posted February 10, 2010 Hi Alex you might find the ignition lock has to be turned to pos 1 and on top of ingnition casing there is a hole you have to push something thin down to push pin in to release ignition barrel...other than that you need the casing as well....hope this helps yeah i read that in the manual it needs to be on pos 1 to remove just the lock, obviously with me not having the key i'll have to remove the whole thing, luckily i have the whole thinge with the bonnet catch etc. so should it just unbolt and the steering lock come off with it? also, any ideas on getting the fuel cap off, since thats locked on too lol. cheers Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted February 10, 2010 Share Posted February 10, 2010 (edited) you have to take all the ignition case off and swap it....as for fuel cap either drill in to it and turn with screw driver or just bang a screw driver into it as all scumbags do when the nick them...hope this helps Edited February 10, 2010 by shaun Quote Link to comment Share on other sites More sharing options...
Guest Alex48 Posted February 11, 2010 Share Posted February 11, 2010 you have to take all the ignition case off and swap it....as for fuel cap either drill in to it and turn with screw driver or just bang a screw driver into it as all scumbags do when the nick them...hope this helps ah great, i've took the day off tommorow to get it sorted, will post results. thanks Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 11, 2010 Share Posted February 11, 2010 hope all goes well mate Quote Link to comment Share on other sites More sharing options...
Guest Alex48 Posted February 12, 2010 Share Posted February 12, 2010 all sorted went pretty smoothly, just need to tackle the fuel filler cap tommorow and i'll be sorted Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 12, 2010 Share Posted February 12, 2010 glad to hear mate smash a big screwdriver in the cap mate that should sort it Quote Link to comment Share on other sites More sharing options...
LeeMcCarthy Posted February 12, 2010 Share Posted February 12, 2010 well done m8 fuel caps are easy to take off Quote Link to comment Share on other sites More sharing options...
Guest Alex48 Posted February 12, 2010 Share Posted February 12, 2010 well done m8 fuel caps are easy to take off yeah your telling me lol, tried to whack a huge screwdriver in with no luck, no damage either.. tried a smaller one, pushed it in slightly and turned it and it works just as good as they key every time lol, got my new one coming off ebay too Quote Link to comment Share on other sites More sharing options...
Guest Alex48 Posted February 12, 2010 Share Posted February 12, 2010 one more thing while i'm on, i need to get the car on the axel stands again tommorow to finnish off the fuel pump properly, quite a while before it went, in hot weather if the tank was pretty full the fuel seemed to treackle out of the filler cap and every time i'd fill it up with petrol it would gurgle and spit it back out unless done really slowly. can't see any breather tubes or anything that could get blocked, any ideas? thanks again guys Quote Link to comment Share on other sites More sharing options...
Guest Alex48 Posted February 13, 2010 Share Posted February 13, 2010 well she runs now, had a sneakyspin around the estate, need to do the rocker gasket as it spits oil when it boosts. any ideas on that fuel problem or should i make a proper thread on it? done it earlier after sorting the new pump out, spat a load of petrol back out Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 14, 2010 Share Posted February 14, 2010 start a thread on it mate as ppl will not know this question is in this topic cos of the title, Quote Link to comment Share on other sites More sharing options...
LeeMcCarthy Posted February 14, 2010 Share Posted February 14, 2010 have you checked the one on the filler neck Quote Link to comment Share on other sites More sharing options...
