Subframe Issues
Guest SteveB
Guest SteveB
hello can anyone tell me if the rs2000 subframe is in anyway different to the 1.8 zetec si subframe as i have recently done a conversion and kept in my 1.8 subframe but now i am having regular issues with tracking and this is a fact which is niggling in the back of my mind thanks peeps
Guest murcus
i would have thought that ford would have kept the same subframes for the mk5, as they did with the mk4
the only way of knowing, is measuring it up, but if all the gearbox mounts etc line up, then im sure that would be fine
what mounts did you use?
