Paris Blue Mk4
iansoutham
When you get a HID kit go for the mechanicaly operatated Bi-Xenon kit !!! :wink:
I've had a Bosch HID kit fitted in it for just over a year now. Full bi-xenon kit with 6000k light level
  • Replies 67
  • Created
  • Last Reply
Top Posters In This Topic
Cool, get some pics up matey, links to where you got them too as a few people have asked about them !!! :biggrin:
I have a H1 10k kit on my Mk6 as I have Projector headight, the bulbs are pleanty bright but the projectors limit the spread of light which is a shame !!! :wacko:
When I go round to the garage next in daylight, I will see what I can do for you.
I got my kit from a friend who imports them, so got them @ cost price. Unfortunately, current economic climate means he can't take the chance anymore.
If you look on the forums, a bloke calling himself nath69 is a distributor for the very good quality ones and his prices are quite cheap. I would recommend him to most people.
Aye up Ian, long time no see, How ya holding up these days?
Glad to see the attentions back on the cab, thought we'd lost you forever to the sierra side :cool:
You know I've always been around in the background.
Still got the Sierra(s). The runaround 2000e has now had its full restoration :biggrin: and the 4be of mine is now retired from the show circuit except for extreme circumstances.
I actually did more miles in the cab last year than I had in the previous 2 years :wow:
I think in 2007 I only pulled it out of the garage 7 times, and 5 of them were to get things out from behind it :unsure:
Ask nicely and I may even help out with the advice again :smile::tongue::wink:
Edited by iansoutham
the calipers look really smart mate,
is guna be a shame to put em on n get em dirty lol
nice work
Who says that they will get the chance to gain dirt?
Every time it goes out on the road it gets washed again (including wheels off) before it goes away, and even then it gets a cover over it :biggrin:
Well i may doing a complete opersite of you.
My cab days are soon to be over, once its sold that is....been offered a very nice sierra for peanuts so just maybe the advice i need will be on a yet a subject lol :wink:
In that case, definitely come and speak to me before you get it.
Being (until recently) the Vice President of the Owners Club means that I get to know a "little" bit about the marque.
For info on the cars, etc.. you can check out the resto threads of the 2000e if you wish
http://passionford.com/forum/showthread.php?t=228531
http://passionford.com/forum/showthread.php?t=243475
  • 2 months later...
Well, minor update time.
Goodridge brake hoses will not be happening right this moment due to funding (ain't got any spare ATM). But, as DOT 5.1 brake fluid is FOC for me, it will be easy enough to swap it all over @ a later date.
Due to the lousy weather recently when trying to fit the front brakes, they had been left for a short time and I turned my attention to the radiator fan cowling which has been bugging me since last year.
So, it went into work and got attacked during lunch.
Have not got any good pictures of it before, but suffice to say that it was absolutely rotten where the water sits. So, a quick grind and some slight reworking later, it ended up in some primer and some paint.
Touch-up sections of etch primer in preparation for final primer coat
Inside of the cowling finished
Well, brakes are basically done....
All fitted, bled and happy.
Will get some better pictures when it comes back out the garage as most of the ones I took came out rubbish (rushing mainly).
Need to find a couple of new bleed nipple caps and that should be it until I can afford the brake lines.
On a better note, the radiator cowling is also finished.
Also took the fan unit apart and started on that. All rubbed back down and given 2 coats of etch-primer before applying a medium heat (paint stripper gun :lol ) and then lightly spraying 3 coats of high-build primer over the surface with additional heat between coats. This has given a nice "stippled" effect which was then finished with a coat of Renault "Champagne" body and bumper moulding spray.
Cowling and fan are finished....
... and all fitted back together....
Did not want the fan motor body in silver or anything similar as it would look obviously painted. What I was after was something a little more subtle. I think I have managed it, opinions???
After all the engine bay work, it has been decided that the cambelt cover is kind of letting the side down, so it is also in for the "refurb" treatment.
Started off with a spare cambelt cover from a spare engine.
Pretty standard sort of condition I would say...
After some careful "preparation" of the surface to be worked, it was out with the specialist plastic bumper repair kit we use in work.
After that had dried, it was rubbed down to show any "low spots" which then had another layer applied
Once rubbed down, it was time for a quick "guide coat" to see if any imperfections remained which were then filled with a "stopper".
This was then rubbed back and ended up looking like this
Next was into the paint booth to get a couple of light coats of specialist plastic primer which was then left to set naturally overnight
Bit more rubbing down of the plastic primer until I was happy with the finish, then onto the actual primer
Next was a guide coat of grey
Followed by finishing the recesses (bolt hoes, etc)
and the semi-finished product frying nicely
Have now fitted the cleaned rubber seal back on and attached with an adhesive rather than horrible staples, so should stay on for longer.
Guest FearNoFoe
wow you have put some serious work into this restoration!
i have enjoyed reading through this thread, car looks absoloutly mint mate
Guest dee1orean
Enjoyed reading this thread mate.
I have to admit when it comes to some of the finer details I can be a bit sloppy seeing the work you've put in to such items like the cam cover and fan puts me to shame!!! Yet it has inspired me to source some spare calipers and drums for a bit of a rebuild!
Cheers mate.
Jez.
The Cambelt Cover and Radiator Cowling came up a treat mate, they look like new !!! :banana_dance:
What did you paint the Radiator Cowling with as it looks stippled ??? :happy:
The inside of the cowling is coated in a protective sprayed-on stone-chip before being over-painted as that is where the water sits. This way, the water does not sit on the metal or paint directly.
Guest markeyboy
some real good work ya doing here,
is guna look real smart when its done mate, looking foward to seeing the finished article now
Thats the descrption I ment but I had Brain Freeze lol !!! :happy001:
Looks smart mate !!! :banana_dance:
  • 6 months later...
Next (small) update...
As the car is now officially off the road until next year I thought it would be an ideal time to start on some more of the "niggling" jobs.
Take 1 standard front antiroll bar mounting plate (which was brand new under 2 years ago :shock :shock ) and remove original bush.
Take 1 uprated Sierra front antiroll bar polyurethane bush (note the extra material in the middle for added rigidity)
... and 1 pair of brand new Ford Sierra antiroll bar clamps and we have an uprated kit :thumbs
The mounting plates do need to be shotblasted back to bare metal and then painted or enamelled accordingly.
Almost forgot about this sitting in the garage as well :cry
Brand new galvanised fuel tank sitting waiting fitting over the winter
