Trunk Lock Removal
Guest ford
Hei guys, i am thinking to remove the rear lock on the trunk before i paint it.The only thing i dont know is what can i do to open the trunk?
Guest markeyboy
fit a solenoid inside the boot which is connected to the boot latch, when ya put 12 volts on it it will activate and pull the mech up same as pushing the button/thurning the key
pretty simple to do,
