Sign in to follow this
Paul
Power Roof Motor Repair Kit
In Stock
The Escort Cabriolet Club as managed to source a few Power Roof Motor repair kits. These repair kits are not available from Ford and will save you loads of money. 90% of the time when your roof will not go up and down but you can hear the roof motor spinning it is because the plastic cog within the pump as cracked. This seems to be more common on the Mk5/6 than on the Mk4's but i guess its because not as many Mk4's had power roofs. The kit contains a new plastic cog, new seal and new bolts and instructions.
Priced at £40.00, this might seem like a lot of money but a new pump will cost you £800.00 plus from Ford.
These can be purchased in our Merchandise Section
Share this post
Link to post
