Guest djadamx Posted May 8, 2008 Share Posted May 8, 2008 i HAVE A 1994 MK5 1.6 16V .I HAVE NO ABS AND THE ABS LIGHT IS ON ALSO BREAK PEDAL IS QUITE HARD DOES ANY 1 HAVE ANY IDEAS AS I HAVE TAKEN IT 2 TWO MACHANICS AND THEY DID NOT HAVE ANY IDEA. THANKS Link to comment Share on other sites More sharing options...
Vincygav Posted May 13, 2008 Share Posted May 13, 2008 If the light comes on after you drive the car, then it is likley to be the sensors. If it comes on instantly when ingition is turned on and does not go out, then it could be the pump faulty, relay, or break in the wiring somewhere. Link to comment Share on other sites More sharing options...
Guest djadamx Posted May 15, 2008 Share Posted May 15, 2008 If the light comes on after you drive the car, then it is likley to be the sensors.If it comes on instantly when ingition is turned on and does not go out, then it could be the pump faulty, relay, or break in the wiring somewhere. I went to see the machanic today and he said he was gonna change the relay .Thanks for your help Link to comment Share on other sites More sharing options...
