ELK100 Posted October 6, 2017 Share Posted October 6, 2017 Hi, This is my first post so I hope someone has come across a similar problem? I upgraded my front windscreen of my 1996 cabby ghia to a heated front windscreen. All worked well until recently when the switch light came on very briefly then went off. It continues to do this when the switch is depressed and there's no front windscreen demisting. The switch is not at fault as I've changed it for the one in my Ghia X that I know works. I don't think its the relay as I've swapped that as well. I've disconnected all the plugs and sprayed them with wd40 in case there's dampness present. So I'm at a bit of a loss. Any suggestions anybody? Link to comment Share on other sites More sharing options...
Paul Grainger Posted October 7, 2017 Share Posted October 7, 2017 Time to get the multimeter out! Does the relay click? That will tell you which side of the relay is faulty. Link to comment Share on other sites More sharing options...
ELK100 Posted October 12, 2017 Author Share Posted October 12, 2017 No the relay didn't click, so one ebay relay purchase later and the front heated screen works again. Thanks for the tip. Link to comment Share on other sites More sharing options...
Paul Grainger Posted October 15, 2017 Share Posted October 15, 2017 Great stuff! Link to comment Share on other sites More sharing options...
