zygott Posted May 25, 2016 Share Posted May 25, 2016 hi i have a 1990 efi xr3i,with a slight misfire. there is a grey box on top of the coil pack, i have been told this is an ignition amplifier. if i unplug this the car runs the same! i have used a multimeter on the wire and its showing 10 ohms resistance to earth. there are a few cracks in the wire, there is only 1 wire connecting to the unit, and its bolted to the metal cage the coil pack is mounted to. could the unit be faulty and that is causing the misfire? the car is drivable, but you can feel the misfire at constant speed. Quote Link to comment Share on other sites More sharing options...
Stephen Bearded Minky Hill Posted May 25, 2016 Share Posted May 25, 2016 I have just changed my spark plugs to Bosch fr6dcx instead of ngk and it has made a world of difference. I think that grey module is a suppressor. Other things I have tried are the throttle position sensor on the throttle body and the map sensor. But the plugs by far have made the biggest difference. Quote Link to comment Share on other sites More sharing options...
jinks Posted May 25, 2016 Share Posted May 25, 2016 hi chap had the same problem change every thing . in the end I git a superchip off ebay and job done drive fine . just a little judder on tick over but think that might be the motor craft plugs I got in . stephen were you get those plugs from mate Quote Link to comment Share on other sites More sharing options...
jinks Posted May 25, 2016 Share Posted May 25, 2016 sorry also when I unplug the grey plug I am shore mine stops running il check that to moz Quote Link to comment Share on other sites More sharing options...
Stephen Bearded Minky Hill Posted May 26, 2016 Share Posted May 26, 2016 My local factors could get em but there was like a £7 delivery charge for Bosch bits so I got em off ebay. Honestly give em a go it's like a new car lol Quote Link to comment Share on other sites More sharing options...
jinks Posted May 26, 2016 Share Posted May 26, 2016 sweet mate il order some up when off me holls Quote Link to comment Share on other sites More sharing options...
jinks Posted May 26, 2016 Share Posted May 26, 2016 unplugged the grey thing it run the same Quote Link to comment Share on other sites More sharing options...
