Guest 90_Spec Posted May 14, 2016 Share Posted May 14, 2016 Morning all, After a few years of non ford ownership and driving a "nice" motor, I got the itch again. I've previously owned a very late Mk4 XR3i and a B Plates series 1 turbo, both of which required many hours of welding. 6 years have passed and I found this one on gumtree for a reasonable price, local and seems all there. It's my first Cabby and I intend to get her back to a nice condition. I'm pretty sure the inner sills are fine, but the outers could do with some attention. As its my first cabby has anyone any advice on replacing outer sills? Better to patch than to replace? I know they have the support beam running through them but does this make it easier to replace the outer dill as structural rigidity is retained? Any advice would be gratefully received. Update with pictures soon :-) Rich Quote Link to comment Share on other sites More sharing options...
Guest jimmyush Posted May 14, 2016 Share Posted May 14, 2016 looking forward to seeing it! i have no experience with the sills but im sure somebody will be along with some help... will it be on the road for this summer? Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted May 14, 2016 Admin Share Posted May 14, 2016 welcome to the cabby club rich :>) depends on the area of rot to be honest as to patch or replace if you look underneath you will see the extra support / strength look forward to lots of pics regards Ollie :>) Quote Link to comment Share on other sites More sharing options...
Guest 90_Spec Posted May 14, 2016 Share Posted May 14, 2016 Hi All, well i do have pics from yesterday, but the site wont accept my URl from photo bucket.. how do you guys get pics up? It looks like its mostly outer sill at the front and rear, middle is fine, and a small potion of the support beam is rotton, but im thinking i can plate that. id really like to do a nice job, im just weary of removing too much strength for welding Quote Link to comment Share on other sites More sharing options...
Guest 90_Spec Posted May 14, 2016 Share Posted May 14, 2016 Quote Link to comment Share on other sites More sharing options...
RScab Posted May 14, 2016 Share Posted May 14, 2016 Welcome to the Club Rich This may help m8 http://www.escortcabrioletclub.co.uk/forums/index.php?/topic/25434-escort-mk3-mk4-floor-sill-detail/ Quote Link to comment Share on other sites More sharing options...
Guest 90_Spec Posted May 14, 2016 Share Posted May 14, 2016 thanks RS Cab, So im guessing the only commercially available panels will be floor pan, inner and out sills, with the other bits being no existent, well i think there should be enough strength in the chassis to allow me to remove the entire outer sill looking at that, then whack a new one on ! other thing, the bottom of the front and rear arches have gone too, both still solid from about 5 inches up, but ive never done a wheel arch, again, is it better to use the entire repair panel, or try and just use what you need? the other 2 escorts ive done was mostly floor pans and a bit of inch angle along each sill to repair the seam Series 1 i did below Quote Link to comment Share on other sites More sharing options...
RScab Posted May 14, 2016 Share Posted May 14, 2016 TBH Rich the only panels available, floor & sills will be the same as the Tintop I prefer to replace the complete panels - a lot more work but normally looks better as for the support sections you'll need to fabricate your own panels or patch as required It also depends on availability of the panels and costs tho Quote Link to comment Share on other sites More sharing options...
Guest 90_Spec Posted May 14, 2016 Share Posted May 14, 2016 well looking on the net, most panel suppliers do the sill sand wheel arches, in fact there is still quite a lot available for the old escorts.. luckily. http://www.carz2.co.uk/escort-mk34-1980-to-90-4590-c.asp Ill look into doing the entire wheel arch repair panel then, front entire wing and outer sill, should be a tidy job tho, Just hope the weather holds out for a few weeks Im also thinking of going the turbo route, am i right in thinking its only the bottom end and turbo that are needed as its already EFI, with of course the ECU and MAP sensor? Perhaps a Motec ECU thanks RS Cab Quote Link to comment Share on other sites More sharing options...
Guest 90_Spec Posted May 25, 2016 Share Posted May 25, 2016 Ok, Sills on the way to going in, I really need a fuel tank sender/pump gasket as mine is foobar. Anyone know the right one for a 90 spec EFI? as i cant find one on the net for the life of me, local ford man wasn't too helpful either thanks in advance Rich Quote Link to comment Share on other sites More sharing options...
Guest 90_Spec Posted May 25, 2016 Share Posted May 25, 2016 Found it, This site is extremely usefull for almost ANY Finis part Hover over the question mark on the right for a description of the car it will fit http://eucatparts.com/?action=cat_ford Quote Link to comment Share on other sites More sharing options...
RScab Posted May 25, 2016 Share Posted May 25, 2016 Did you get a Brand New seal Rich? Quote Link to comment Share on other sites More sharing options...
Ian71 Posted May 25, 2016 Share Posted May 25, 2016 If it's 90 spec has it got the fuel computer,if so I think it has the 4 inch tank opening rather than the 2 inch ,I struggled to find the bigger sender unit on mine. Quote Link to comment Share on other sites More sharing options...
RScab Posted May 25, 2016 Share Posted May 25, 2016 Think he was only after the Seal Ian Quote Link to comment Share on other sites More sharing options...
jinks Posted May 25, 2016 Share Posted May 25, 2016 hi if any one finds were to get a sender tank seal efi 4 inch please give me a shout had my tank off a few times lol Quote Link to comment Share on other sites More sharing options...
jinks Posted May 25, 2016 Share Posted May 25, 2016 also just a quick tip you might already know don't leave the car jacked up on the body cabs don't like it they bend I left mine jacked on all 4 wheel points , learnt the hard way when open door and did not shut lol Quote Link to comment Share on other sites More sharing options...
