Guest MICKEY P Posted May 3, 2016 Share Posted May 3, 2016 Can anyone help im looking for a fuse box for my cabbie 1,6,zetec Mreg looked everywhere ebay gumtree breakers but no luck any help would be appreciated......GREAT SITE ..........94AG14073BAA THANX Link to comment Share on other sites More sharing options...
ianxr3i Posted May 18, 2016 Share Posted May 18, 2016 Hi, I might be able to help with your fusebox. I have got a brand new fusebox with the part number 95AG14073AB. If you check with your local Ford dealer they should be able to check to see if it is useable. Have a look at the picture attachment Link to comment Share on other sites More sharing options...
Guest MICKEY P Posted June 6, 2016 Share Posted June 6, 2016 Hi thanx for the info i just happed back on her aging and found your post i thought any replays might have poped up in my own email box ...sorry that's why this is a late response ...do you still have it thanx Link to comment Share on other sites More sharing options...
ianxr3i Posted June 8, 2016 Share Posted June 8, 2016 Hi thanx for the info i just happed back on her aging and found your post i thought any replays might have poped up in my own email box ...sorry that's why this is a late response ...do you still have it thanx Yes I do still have the fusebox Link to comment Share on other sites More sharing options...
allblue Posted June 8, 2016 Share Posted June 8, 2016 There are loads of variants of these boxes, all dependent on year and also spec levels. I doubt that will work on your model as the part number is different. You need one that matches the one you have already. Or you can do what I did and resolder all joints. I did this eight years ago on mine and it is still going strong. Link to comment Share on other sites More sharing options...
Guest username Posted June 10, 2016 Share Posted June 10, 2016 that's probably the best/cheapest/easiest and quickest way forward in this case provided you have a decent soldering iron, starting with a fusebox that's guaranteed to be the correct one for the car and cleaning all corrosion out/remaking connections and maybe going one step further (once the box is tested and known working) could be to seal all but the actual terminals with silicone/paint/resin. Link to comment Share on other sites More sharing options...
Vincygav Posted June 28, 2016 Share Posted June 28, 2016 Make sure the last 3 letters/numbers match. Try ebay Link to comment Share on other sites More sharing options...
