Guest Risolver Posted April 26, 2016 Share Posted April 26, 2016 Recently had problem with bonnet release on 97 cabriolet.Now fixed and new battery installed. Since then, no power reaching the audio system, and more upsetting, the power roof doesn't work. Is this repairable? Not ready to part with the car yet, and want to get another summer out of it! Please help? Quote Link to comment Share on other sites More sharing options...
Vincygav Posted April 30, 2016 Share Posted April 30, 2016 have you checked the fuse hasn't blown. Think its a 15 amp for the radio. Power roof only works in key position 1, unless you remove the inhibitor relay to allow you to run it with the engine on. Quote Link to comment Share on other sites More sharing options...
Himanshu Posted May 3, 2016 Share Posted May 3, 2016 Check the relay, and check all continuity is there, I.E a good ground, that a power supply shows, and the switched live is present. Quote Link to comment Share on other sites More sharing options...
