Guest Fordstevie77 Posted November 11, 2015 Share Posted November 11, 2015 Right i am going to be installing a Kenwood cd player which has the Blue wire for power to aerial... At the rear of car is 2 wires that go into a small white 3 pin connector block: 1 is Pink which I have chased back to ignition 1 is black/white which is chased back to audio loom not connected to anything From what I understand the electric aerial needs permanent live, switched live from head unit and earth.. So what is the pink and black wire for as in Haynes manual it states Red/White to stereo which is also there not connected???? and if pink is ignition than is it switched and not permanent....??? Cheers in advance for picking anyones brains Quote Link to comment Share on other sites More sharing options...
Guest Fordstevie77 Posted November 18, 2015 Share Posted November 18, 2015 Anyone...? theres a relay behind dash ford part 81AB15040AA ITS 5 PIN RELAY but theres only 4 wires attached: 1 Red from ignition switch no. 30 1 Black/yellow from ignition no. (looks like 50) 1 Pink goes to rear of car connector for electric aerial 1 Brown earth so where does the black and white supposed to go that's in wirng plug at rear Quote Link to comment Share on other sites More sharing options...
gingergman Posted November 19, 2015 Share Posted November 19, 2015 The brown earth goes either on the side of the dash mount or top of steering coloum bracket, st the aerial you should have one earth, think one black and also a blue. Don't get em mixed with the roof pump loom if its got one Quote Link to comment Share on other sites More sharing options...
