Guest Demonjams Posted August 23, 2015 Share Posted August 23, 2015 Sorry if this has already been covered but has anyone had an issue with the interior courtesy light and boot compartment light I've swapped both the bulbs and checked what I thought was the right fuse but still no joy !!! Just wondered if anyone has ever had this issue, if anyone can, (excuse the pun!!) shed any light on this that would be great. Quote Link to comment Share on other sites More sharing options...
Guest Nelly Rs Posted August 23, 2015 Share Posted August 23, 2015 It's probably the door pin switches need a clean ( they make the earth circuit when the door is open ). I've got the same issue with the boot light I think that has lost its live feed ;-) Quote Link to comment Share on other sites More sharing options...
Guest Demonjams Posted August 24, 2015 Share Posted August 24, 2015 Nice one mate iill give em a clean up and see if that works cheers bud Quote Link to comment Share on other sites More sharing options...
Guest ANDYA Posted September 29, 2015 Share Posted September 29, 2015 Did it work? I had the same problem and it was the ends of the bulb needed cleaned. Had to clean the metal contacts as well and tension them slightly to improve the connection. Andy Quote Link to comment Share on other sites More sharing options...
