Guest Chris Adams Posted July 30, 2015 Share Posted July 30, 2015 I have go spark and fuel but it just wont start i tried towing it but it sounds dead like all four pistons just dont want to work together Quote Link to comment Share on other sites More sharing options...
Guest Chris Adams Posted July 30, 2015 Share Posted July 30, 2015 I've got spark and fuel but no starting what else must i check? Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 30, 2015 Share Posted July 30, 2015 Belt snapped? Quote Link to comment Share on other sites More sharing options...
Ian71 Posted July 31, 2015 Share Posted July 31, 2015 Cam belt snaped as stu says or have you got the ht leads on the wrong spark plugs ? Quote Link to comment Share on other sites More sharing options...
a1dale Posted August 1, 2015 Share Posted August 1, 2015 compression test is the first thing before throwing loads of time and money on it. Quote Link to comment Share on other sites More sharing options...
Guest Derickdixon Posted August 1, 2015 Share Posted August 1, 2015 If there is a spark and the plugs are wet with petrol ,there is only a choice of two . One is the firing order correct ? Two is there compression ie. Burnt out valves or head gasket Quote Link to comment Share on other sites More sharing options...
