Mk 6 Escort Cabriolet Roof Not Working Advice Needed
Guest Zanhar25
Guest Zanhar25
Unfortunately my newly acquired escort Cabriolet roof is not working at all, when I agreed to buy the car I was told that the roof went down but won't go up but you could hear the pump.But today when I tried it it doesn't seem to work at all. I tried position 1 etc as I read on here to no avail.
Wher are the fuses found for the roof?
Does any one have a proper wiring diagram for the roof circuit?
Any advise greatly recieved.
Thank you.
  • 2 weeks later...
Guest Zanhar25
Thanks for you suggestions, since this post I now have a working roof.
The fault was a faulty 15A circuit breaker and the pump also needed topping up.
It's been ok since but I do wonder where the oil went but I'll keep monitoring the levell
  • 3 months later...
Guest Zanhar25
Update, last week roof wouldn't shut fully, oil low again. Investigated further and discovered the "o" ring on the pump (motor side) was weeping. Replaced o ring now all OK again.
