Guest Glenn65 Posted March 29, 2015 Share Posted March 29, 2015 Here's a question. the temperature stays down when moving, but if sitting still starts to rise ok. Goes back down if you move off. I've changed the thermostat and can't see anything else obvious. The fan not kicking to early either. Any ideas? Quote Link to comment Share on other sites More sharing options...
Ian71 Posted March 29, 2015 Share Posted March 29, 2015 Thats normal glen for a cvh engine,they do run hot when standing still,and when you are moving cool air through the rad cools it down again. I have fitted twin fans to my two cars one off the thermostat and one off a switch in the car which i can control in atraffic jam before the engine gets to hot. Quote Link to comment Share on other sites More sharing options...
Guest Glenn65 Posted March 29, 2015 Share Posted March 29, 2015 Cheers Ian, but mine is lucky to hit half way and drops right down below the bottom line when moving. I may try a higher degree thermostat, recon the one I've got in is an 88' one. It is still cold at the mo here so may change in the "summer" lol Quote Link to comment Share on other sites More sharing options...
Guest El87cabi Posted March 29, 2015 Share Posted March 29, 2015 Have been having the same problem with my 90' efi mk4, didn't do it when i bought the car then started at some point during the restoration, not had the issue before, my 87' mfi used to sit between the O and R of NORM as it should do Quote Link to comment Share on other sites More sharing options...
