Guest ben smith Posted February 2, 2015 Share Posted February 2, 2015 As per the title I press the button get and it lights up but the screen actually doesn't warm up not in the slightest I have checked the fuse and the terminals on the window and they seem fine Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 2, 2015 Share Posted February 2, 2015 Check the earth on the parcel shelf passenger side Quote Link to comment Share on other sites More sharing options...
RScab Posted February 2, 2015 Share Posted February 2, 2015 Connect a volt meter (or a 12v bulb) across the terminals if you get power - then the heater element on the glass is faulty Quote Link to comment Share on other sites More sharing options...
Guest ben smith Posted February 3, 2015 Share Posted February 3, 2015 Didn't think about using a bulb such a tool sometimes Quote Link to comment Share on other sites More sharing options...
Guest ben smith Posted February 4, 2015 Share Posted February 4, 2015 So after a quick check with the fluke turns out either the window has had it or the the connections on the edge of the window have it actual circuit is gd Quote Link to comment Share on other sites More sharing options...
RScab Posted February 5, 2015 Share Posted February 5, 2015 New glass then Ben Quote Link to comment Share on other sites More sharing options...
Guest ben smith Posted February 24, 2015 Share Posted February 24, 2015 Might just give it a damn good ignoring tbh cos that's gonna be costly Quote Link to comment Share on other sites More sharing options...
Guest ANDYA Posted February 24, 2015 Share Posted February 24, 2015 What about one of these; http://www.ebay.co.uk/itm/12V-12-Volt-Ceramic-Car-Van-Fan-Heater-Warmer-Window-Defroster-Demister-RSter37R-/121199011948?pt=LH_DefaultDomain_3&hash=item1c3806286c you could connect it in to the existing wiring for the heated rear window. There are others on the site. Quote Link to comment Share on other sites More sharing options...
Guest ANDYA Posted February 24, 2015 Share Posted February 24, 2015 Or even this; http://www.ebay.co.uk/itm/escort-xr3i-cabriolet-tinted-green-rear-screen-sigla-breaking-mk3-cab-se500-mk4-/141579446116?pt=LH_DefaultDomain_3&hash=item20f6cae764 depends if you live near enough. Quote Link to comment Share on other sites More sharing options...
