Guest fitterman2 Posted November 12, 2014 Share Posted November 12, 2014 hi, my headlights just packed in, ive checked the fuses an bulbs, main beam and side lights work, any one had this problem? Quote Link to comment Share on other sites More sharing options...
Guest fitterman2 Posted November 12, 2014 Share Posted November 12, 2014 (edited) UPDATE tried switch still no headlights, no power going to fuse box Edited November 12, 2014 by fitterman2 Quote Link to comment Share on other sites More sharing options...
Vincygav Posted December 2, 2014 Share Posted December 2, 2014 Have you checked the relays. If you have changed the multifunction switch for another one - are you 100% sure that it works ok. They are known for going bad. Quote Link to comment Share on other sites More sharing options...
Guest Tommy. 01495 Posted December 3, 2014 Share Posted December 3, 2014 9 out of 10 it's the switch I delete this all the time in my years tim Quote Link to comment Share on other sites More sharing options...
Guest Tommy. 01495 Posted December 3, 2014 Share Posted December 3, 2014 You can fix this by spraying carb clean in to the switch turn on of two or three times then we 40 and blowing out with air line will work Quote Link to comment Share on other sites More sharing options...
