Guest paulizkyc Posted October 25, 2014 Share Posted October 25, 2014 Hi I am new and am wondering if anyone else has had this problem. I have a standard radio in my mk 5 escort xr3i and it works fine until I turn the headlights on and then the radio go off and if I turn the lights off and turn the radio back on I have to put the code in again. Any help would be much appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
RScab Posted October 25, 2014 Share Posted October 25, 2014 Check its wired to the correct power source perminant live & ignition live Quote Link to comment Share on other sites More sharing options...
Guest paulizkyc Posted October 27, 2014 Share Posted October 27, 2014 Thanks I will have a look at it this weekend Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted October 27, 2014 Share Posted October 27, 2014 Ditto the wiring. The radio going off when lights are on is normally a sign of alternator bushs being worn so not enough charge. Voltage drops and radio goes off. Though this would never be below the point to wipe memory and make you enter the code each time. That is unless the whole car is cutting out because the battery is dead? Quote Link to comment Share on other sites More sharing options...
Guest paulizkyc Posted October 28, 2014 Share Posted October 28, 2014 No the car isn't cutting out it is like the fuse it blowing but it would isn't. Quote Link to comment Share on other sites More sharing options...
