Guest moondancer Posted September 29, 2014 Share Posted September 29, 2014 Hi all , help needed please , my 1989 xr3i cab has just had a large patch of oil on the floor under the front of the car , could it be an oil pipe !! Cab is in excellent condition , no rust always started first time and been fabulous runner. Link to comment Share on other sites More sharing options...
StuDaBear Posted September 29, 2014 Share Posted September 29, 2014 Could be all manner of things leaking, if you have a jack and axle stands you might need to safely support the vehicle up on stands and get under with a torch and have a look. Link to comment Share on other sites More sharing options...
Guest moondancer Posted September 29, 2014 Share Posted September 29, 2014 Thanks StuDaBear , will take a look tomorrow , not sure what I shall be looking for but will give it a go. Moondancer Link to comment Share on other sites More sharing options...
Ian71 Posted September 29, 2014 Share Posted September 29, 2014 Clean all the excess oil off,then start car up get it warm and see where it is coming from.As stu says could be a few differant places.Good luck. Link to comment Share on other sites More sharing options...
Guest moondancer Posted September 29, 2014 Share Posted September 29, 2014 Will post tomorrow once I have taken a look , could be a perished pipe!! Link to comment Share on other sites More sharing options...
StuDaBear Posted September 29, 2014 Share Posted September 29, 2014 Sump gasket. Sump, front crank seal, rear crank seal, dipstick seal, cam cover, distributor oil seal, camshaft oil seal are all possibilities. Link to comment Share on other sites More sharing options...
