Guest Josclark Posted July 30, 2014 Share Posted July 30, 2014 If I put the hood up (Mk 5) before starting the engine in the morning, the engine will not start except with a push start. Thereafter, once started, it will start all day long (whilst hood down). There must be some disabling switch/relay/fuse I need to sort. I know not what. Any help will be gratefully received! Thanks. Quote Link to comment Share on other sites More sharing options...
Vincygav Posted August 3, 2014 Share Posted August 3, 2014 Using the hood before starting could be causing battery drain. Try starting the engine, run for 2-3 mins, then switch off, then raise the hood, it should have power to restart. Quote Link to comment Share on other sites More sharing options...
Guest Josclark Posted August 9, 2014 Share Posted August 9, 2014 Thanks for this. Tried it, although the battery is fairly new. Not resolved. Must be electrical/switch issue............. Quote Link to comment Share on other sites More sharing options...
