Guest mrsters2000 Posted July 15, 2014 Share Posted July 15, 2014 Hi i have a mk3 cab that i,ve restored over the last 3 yrs,its only a 1.4cvh but hey ho for a £100 can,t grumble! i,ve replaced the old dash for an rs1600i one but when the engines running all the red warning lights across the bottom stay on and when the ignition is turned off all go out except the brake light that slowly fades out..! any ideas please, its been in storage since 1993 and i,m determined to get in on the road by the weeks end [ make the most of our glorious summer ] lol Steve Quote Link to comment Share on other sites More sharing options...
Guest CHESSYDAVE Posted July 15, 2014 Share Posted July 15, 2014 have you also changed the clocks if so just plug old ones in and see if they do same if they do I could be a earth be careful I have just lost my to a fire due to wireing fault I restored her but now sad shes gone hope this helps Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted July 16, 2014 Admin Share Posted July 16, 2014 Make sure the blue box just behind the centre speaker is ok and plugged in That controls all the dash lights Few on eBay Worth a try :-) Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted July 16, 2014 Admin Share Posted July 16, 2014 have you also changed the clocks if so just plug old ones in and see if they do same if they do I could be a earth be careful I have just lost my to a fire due to wireing fault I restored her but now sad shes gone hope this helps Sorry to here that Dave :-( Quote Link to comment Share on other sites More sharing options...
Guest mrsters2000 Posted July 21, 2014 Share Posted July 21, 2014 thanks for that info, sorry long time replying ,but i,ve been working on it every second i get. the blue box you mention is green on this car and guess what? the big long multi plug was not plugged in at all... so i fixed that and hey presdo STILL THE SAME ..!is it worth cleaning up the conections that go into the fuse box from underneath. spotted that someone had cut the BLACK wire and the BLACK with YELLOW stripe wires that go to the ignition switch and joined em wrong [bLACK TO BLACK/YELLOW and BLACK/YELLOW to BLACK ] put them back properly then the car would turn over but not start..! ive a feelin this car hates mm, might give up and get me mk2 out ;} Quote Link to comment Share on other sites More sharing options...
Guest mrsters2000 Posted August 6, 2014 Share Posted August 6, 2014 Been away to " SKEGG VEGAS" last week, came home Sat. To find the green control box I got off eBay had arrived, fitted it and it has nearly cured the dash lights staying on! Now only one stays on, must still be a bad earth. Taking it for it's mot later. Fingers crossed! I will try to put some pics up later ( if I can figure out how, totally useless on computers) give me a socket set any day! Quote Link to comment Share on other sites More sharing options...
Himanshu Posted May 20, 2015 Share Posted May 20, 2015 This is most likely to an earth (ground) fault. Get a competent auto electrician they usually charge £50 p/hr. but it might be £50 well spent. These cars had a history of poor earthing problems. Quote Link to comment Share on other sites More sharing options...
