Mk3/4 Outer Weatherstrips
Guest Rob90spec
Are they the rubber/metal ones that bubble up the doors? and do they do the smaller rears too ? im sure someone has mentioned em before
Awesome as mine are bubbled and if i respray my car this winter as planned they would let it down :sad: project? what they doing to it?
Guest Rob90spec
Well.....funny you should say that,I spent a week of late nights detailing my engine bay and underside and just when i think ive finished till the spring my mate steals my car,strips it down and give me a shopping list of bits to get for when he's finished a respray for me :smile::):smile::)
I think they're making up a few patch panels for common rot spots :smile::)
Guest Rob90spec
Rears are on eBay at the mo.
Might have a trip down after they move to new premises to have a nose at what they got available :smile:
Guest Rob90spec
Inners are the same as outers,
Inner lhs is outer rhs
Outer lhs is inner rhs,
I need rears and inners now,and door handles,and washer hose clips,and bonnet stay clip....................................so much for a quick prep&paint lol
Yep full set
Outer front RH *3
Inner fronts LH/RH - Gen Ford ones are different to the outer ones.
Outer rears LH/RH
Inner rears LH/FH
Windscreen rubber *2
Rear window rubber *1
A pillar rubber strips LH/FH
2 * Door strip end plugs.
All gen Ford. Mind you the rear ones were expensive at £40 pound each (back in 2004).
The front ones and inners were more reasonably priced at around £10 each (2004).
Washer hose clips and bonnet stay clip may still be available from Ford.
Guest Rob90spec
Ive always used SMC ford in gravesend for any bits I've ever needed :smile: top boys down there
Give them a bell,see what they say :smile:
You wish Dennis! LOL
Picked up a new rear wing - drivers side over the weekend too.
Rob 90 spec, good luck with the resto. Saw you other thread. You car is in pretty good condition to start with.
Is it really 53 pounds for a plastic outer handle?
