Guest ben smith Posted August 17, 2013 Share Posted August 17, 2013 i have a set of front fogs i want to fit and wondered how easy it was to fit and is the loom in the car already or will i have to make one up Quote Link to comment Share on other sites More sharing options...
allblue Posted August 17, 2013 Share Posted August 17, 2013 Assuming you are referring to the original ford spotlights,your mk4 should already have the fog light wiring, as it was standard spec. Check for a pair of loose wires by the radiator. Other than the lamps you will need the suitable brackets too. Ollie 1 Quote Link to comment Share on other sites More sharing options...
Guest ben smith Posted August 17, 2013 Share Posted August 17, 2013 yes they are ford orignial lamps aswell as the bracks i was considering making some sort of cluster as i have four of them but didnt know if it was possible and if the wiring for two was there or if i had to make it Quote Link to comment Share on other sites More sharing options...
welshlad Posted August 18, 2013 Share Posted August 18, 2013 My wiring isnt there so does anyone know were it joins the loom or colours of the wires etc in the engine bay ? i could just put some wiring in but have too many jobs to do to it already Quote Link to comment Share on other sites More sharing options...
welshlad Posted August 18, 2013 Share Posted August 18, 2013 Actually it is there ive found them under some tape but they have no power going to them any ideas? fuses are ok Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted August 18, 2013 Admin Share Posted August 18, 2013 think theres a relay for them aswell tony Quote Link to comment Share on other sites More sharing options...
welshlad Posted August 18, 2013 Share Posted August 18, 2013 I didnt have full beam on lol, i did get power for a sec as i heard a spark as a while accidently touched the rad now theres def no power all fuses are ok so perhaps the relay has had it ill try it in the morn as i ve killed my battery ......... Left my lights on Quote Link to comment Share on other sites More sharing options...
Guest ben smith Posted August 18, 2013 Share Posted August 18, 2013 wot about the plug at the back of the dash should that be there Quote Link to comment Share on other sites More sharing options...
