Leak Solution
Guest ben smith
Guest ben smith
I had a leak in my roof where it meets the windscreen.... Aftter weeks of playing I found a solution it sounds a bit like a pikey solution but works a treat simply open the roof and get a push bike innertube (26") cut the valve off and pull over the seal ands them trim to size and warm it up to a mould with a hairdryer or paint stripper heat gun and then melt the ends into place on the seal where it changes onto the door seal leave to set about 20 mins to go cold close roof.... Problem solved no leak at all
  • 4 months later...
I have kinda come up with a part solution due to my cabby roof leaking. I have realised that the rubber seals have a major part in this. I just checked and at the moment it is only the nearside is a very slight drip, compared to before it was letting in a lot, and the offside just a little. The offside appears to have worked.
The pic below shows where water seems to come into the roof seal via the front. This triangular block appears to allow water in as it is not fixed. I had previously put sillicone sealant, but it didnt last at all. I have now bought Stormsure 5g on ebay. This is also good for split roofs.
http://www.ebay.co.uk/itm/STORMSURE-5g-repair-adhesive-fixes-holes-rips-tears-waterproof-clothing-waders-/350673144449?pt=UK_Crafts_Cardmaking_Scrapbooking_Glue_Tape_EH&hash=item51a5bf8a81
Item number:350673144449
When I did use this, not shown in any of the pics, have to take some of it done. I left it for 6 hours before closing the roof.
Water travels further along the triangular block in the seal on the roof itself. It is also worth sealing this up with stormsure as the water can go further back near the pillar.
A wet drivers seat because of these flipping roof seals. The passenger side seat was worse.
This is the passenger side seal that leaks far more than the drivers side at the time. Took this pic when it rained and you can see the water coming through. It was sometimes so bad that it would run further back along the seal and also leak out just before the b pillar. This soaked my rear passenger footwell to a puddle pond.
Blue arrow shows where water comes into the triangular block. There is a normal exit for this by the bottom windscreen door A pillar. I had to get a syringe with hot car wash to pump it down here to clear it out of tree sap etc to allow better drainage. The green arrow shows where it was exiting into the car itself. I had even get felt adhesive pads to try to stem the leak, but it didnt work. Ended up removing them after the pics were taken. And glued the triagular block behind it with stormsure.
I have done a slight modification to the roof now to stop water seeping in through the gap of the window seals.
You can see this where the gap line should be.
I cut 2 pieces of fabric from excess from when I changed the roof. So its matching blue and mohair.
I cut them to 8cm by 3 cm.
I marked a blue line, at the 4cm point, so it would be halfway.
Shows the underside where it has been test fitted to see how it would fit.
The piece of fabric cut to make the seal cover.
The superglue gel applied to the underside
The nearside is finished
The offside is complete
  • 10 months later...
An additional measure to stop leaks I have done recently as I ended up getting more water in with this recent heavy rain. Although these measure I have done posted below have cured it.
1. Was to use a PU polyuthrane sealant like Tiger Seal, to seal the triangular rubber blocks as the stormsure on this had wear away.
2. I then sprayed the roof with Scotch Gard, heavy duty water repellent for outdoor fabrics.
3. I then used some materials to make a slight cover over the gap from the roof material to stop water flowing down into the roof frame.
  • 2 months later...
