Power Roof Plastic Reservoir Cracked
Guest Pepsionline
Guest Pepsionline
Hi all my power roof has a crack in the plastic reservoir. Can anyone tell me where I can get a new one or the part number. It is the part of the power roof motor that you can see the hydrolic fluid through.
Or if you have one I would be happy to buy the plastic reservoir from you
Many Thanks
Paul
Guest El87cabi
Well i'd get ur reg n chassis no and give Quickco a ring, if they can't help you, you'll have to find a second hand 1, google breakers etc, thats how i got my new hood pump :smile: Quickco (Perrys) no is 0208 2073100. Hope that helps el
  • 2 years later...
I noticed that VW seems to do a replacement for this for the Golf. mine is cracked and wondering if I should buy this. It is Volkswagen part number repair set oil container 8G0898101
Seen on an American store http://www.ecstuning.com/ES444991/PriceAlert/
Also a post on it on a Golf forum at http://www.vwaudiforum.co.uk/forum/showthread.php?95913-cabriolet-roof-pump-reservoir
If VW are selling them, I am surprise Ford is not selling them, or are they?
  • 2 months later...
  • 2 weeks later...
Hi my fluid reservoir split also cracked at bottom,I turned the plastic reservoir 180 degrees so the crack are now on top
No fluid leaks,I need to keep checking fluid levels
