Guest RelaxedDiver Posted January 13, 2010 Share Posted January 13, 2010 help cant seem to programme a second pats key on mk6 1998 have put red key in, turned to position 2 4 times in 3 seconds taken out, red light comes on put second key in turn to position 2 and light just flashes fast Any ideas much appreciated. cheers rd Quote Link to comment Share on other sites More sharing options...
RScab Posted January 13, 2010 Share Posted January 13, 2010 Hi M8, What engine is in it? as thats not the sequence I have 4 a 1998 Escort MK6 Quote Link to comment Share on other sites More sharing options...
Guest RelaxedDiver Posted January 14, 2010 Share Posted January 14, 2010 hi dennis its the 1.8 have also tried putting the red key in to position 2, light comes on. take red key out, light comes on put slave in and turn to position 2, pats flashes fast rd Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted January 14, 2010 Share Posted January 14, 2010 There are a few variations, these are the common ones.... 1st option......To programme a new key turn the ignition on with your master key wait a few seconds turn the ignition off and then insert your new key, turn ignition on and this should do it. or 2nd option......1) Insert the red master key and turn to position "I" and back to "O", do this 4 times within 8 seconds, the forth time you go to "I" the LED should illuminate for 5 seconds. 2) Remove the red key within the 5 seconds. LED will stay on. 3) Insert black key to be programmed, and turn to" I "once and then remove. The programming will be confirmed by the red LED going out for 2 seconds and then coming back on. 4) If no other keys are programmed within 30 seconds or any programmed key is turned to position "II", then program mode will be terminated. I notice you said that you turned key to position "II", on some models that just terminates program mode,and that may be the case here.NOTE..... the programming sequence can be different for different years/models. Let us know how you get on. Hope this helps, regards, Tony Quote Link to comment Share on other sites More sharing options...
Guest RelaxedDiver Posted January 14, 2010 Share Posted January 14, 2010 hi, thanks for the reply tony, option one does have the light comming on, where as option two doesnt bring light on at all. however after following the first method i keep getting error code 13 (when using new key)from the pats light saying ist not recognising the transponder in the key. have just noticed that it is a blue bit of plastic in the top of the slave key would this affect it? cheers rd Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted January 14, 2010 Share Posted January 14, 2010 Hmmm, the blue transponder is for later types, this prob explains why its not programming up, code 1.3 means "key code not received" i would have thought yours should have the red transponder in it, i would go back to the dealer and get a black key with the red insert m8 and your problem should then be closer to being solved. Quote Link to comment Share on other sites More sharing options...
