Manual To Electric?
Guest sazzy123
Guest sazzy123
Hi, Is is possible to convert my manual roof to electric and if so where is the best place to go and roughly what cost? I am in York so can take it anywhere in yorkshire. Its a 1991 EFI model. Thanks
yes mate i've done mine it cost me about £80 for the whole kit including loom from ebay it took about 1 hour to fit and theres a guide on this site.
Guest droptopdave
yes very easy to do and very cheap too, my pump off ebay cost me £15.01 and came with the rams, switch on ebay too cost a fiver, and followed the instructions on this site, which are very good , i downloaded the instructions at work so didnt have to keep looking at the laptop for guidance
  • 3 weeks later...
  • 3 months later...
Guest Cabbytech
Yes, it is a straightforward job to convert from manual to electric roof, the first thing to do, is get the pump, rams and the electric bits to do the job.
Hi most parts on e-bay for eletric roof convertions but hardest thing to get hold of is the 4 pins for the rams.there is apost to help you with this as other's have stated
good luck :biggrin:
Guest richie29gt
yep just done mine such a easy job spec as i didnt even use the instructio ns from here and i havent even got the mount ing bolts so all i done was to drill out 2 hole the width of the pump holes and job done
only thing u would be best 2 do is to make sure relays do work b4 you put all your trims back in place as i have found out lol 2 new relays to be ordered now
lol
but good luck
Guest Cabbytech
hmmm, are you sure both relays have failed Richie, its unusual for both to fail at the same time, it sounds like a wiring or supply issue to me.
  • 6 months later...
  • 4 years later...
Guest kathers_1985
Hi, I'm just about to get all the bits to do this could someone give me a list of the parts to make sure he gives them all to me please :smile: Ty x
