Guest peterw1983 Posted December 30, 2007 Share Posted December 30, 2007 i am struggling to locate the fuel pump relay on my escort 1990 cabby 1.6 efi engine please help cheers pete Link to comment Share on other sites More sharing options...
Guest the chunkster Posted December 30, 2007 Share Posted December 30, 2007 (edited) sorry bud cant help ya try a haynes manual Edited December 30, 2007 by the chunkster Link to comment Share on other sites More sharing options...
Guest Eggsy Posted December 30, 2007 Share Posted December 30, 2007 above speaker pod in drivers side footwell - get your head under the dash & have a poke around - should come acroos it somewhere!!! pmsl Link to comment Share on other sites More sharing options...
Guest peterw1983 Posted December 30, 2007 Share Posted December 30, 2007 above speaker pod in drivers side footwell - get your head under the dash & have a poke around - should come acroos it somewhere!!! pmsl yep but which one is it theer is more than one underthere cheers pete Link to comment Share on other sites More sharing options...
Guest steelcabby Posted December 30, 2007 Share Posted December 30, 2007 YELLOW?? FORD ONES ARE PINK AND CONNECTS ONTO A PINK PLUG, BUT IF ITS AFTERMARKET THEN IT WILL BE BLACK USUALLY, BUT IT STILL CONNECTS TO A PINK PLUG Link to comment Share on other sites More sharing options...
Admin Paul Posted December 30, 2007 Admin Share Posted December 30, 2007 sorry guys you are right g its pink Link to comment Share on other sites More sharing options...
Guest steelcabby Posted December 30, 2007 Share Posted December 30, 2007 HANG ON A MINUTE, ARE THEY DIFFERENT ON THE EFI ONES THEN?? OR THE SAME AS THE MFI ONES?? THOUGHT THEY WERE THE SAME Link to comment Share on other sites More sharing options...
Guest steelcabby Posted December 30, 2007 Share Posted December 30, 2007 OH RIGHT....LOL THOUGHT SO, YOU CONFUSED ME THERE FOR A SECOND....LOL Link to comment Share on other sites More sharing options...
Admin Paul Posted December 30, 2007 Admin Share Posted December 30, 2007 no mate you are right lol Link to comment Share on other sites More sharing options...
Guest peterw1983 Posted December 30, 2007 Share Posted December 30, 2007 so it is the pink one i need to change cheers pete Link to comment Share on other sites More sharing options...
Guest the chunkster Posted December 30, 2007 Share Posted December 30, 2007 pink or brown pmsl Link to comment Share on other sites More sharing options...
Guest steelcabby Posted December 30, 2007 Share Posted December 30, 2007 so it is the pink one i need to changecheers pete yeah the pink one, unless its an after market one which is probably black, but they plug into a pink connetor anyway......cheers STEELCABBY......pmsl i've just had brown, it was gooooooooood...lol Link to comment Share on other sites More sharing options...
Guest the chunkster Posted December 30, 2007 Share Posted December 30, 2007 lol Link to comment Share on other sites More sharing options...
Guest steelcabby Posted December 31, 2007 Share Posted December 31, 2007 pmsl Link to comment Share on other sites More sharing options...
Guest peterw1983 Posted December 31, 2007 Share Posted December 31, 2007 pmsl hello i have found everyone but the pink one doing my head in now i have got a green one with nothing in a blue one with a blue one in and a red one with a red one in and a yellow one with a yellow one in Link to comment Share on other sites More sharing options...
Guest steelcabby Posted December 31, 2007 Share Posted December 31, 2007 there must be a pink relay under there, or a black one. but either one will be plugged into a pink plug. its under the driver side dash, it may be stuck up somewhere. it is there unless some nancy has moved it for some reason Link to comment Share on other sites More sharing options...
Guest peterw1983 Posted December 31, 2007 Share Posted December 31, 2007 there must be a pink relay under there, or a black one. but either one will be plugged into a pink plug. its under the driver side dash, it may be stuck up somewhere. it is there unless some nancy has moved it for some reason i will find it when i get enougher 5 mins to look thanks for the help most aprecciated and happy new year same to all that is reading this cheers pete Link to comment Share on other sites More sharing options...
Guest steelcabby Posted December 31, 2007 Share Posted December 31, 2007 let us know thw outcome mate, oh and HAPPY NEW YEAR TO YOU MATE Link to comment Share on other sites More sharing options...
Guest peterw1983 Posted January 1, 2008 Share Posted January 1, 2008 let us know thw outcome mate, oh and HAPPY NEW YEAR TO YOU MATE hello mate just had enougher look there is definetly not a pink one under there that i can see and i have been right under there the car i have put down as 1990 is actually a 1989 g reg xr3i cabriolet will that make any difference there is one green with nothing in one yellow with a yellow relay one blue with blue relay one red with red relay and a grey with grey relay black with yellow relay and black with green relay Link to comment Share on other sites More sharing options...
Guest sjc Posted January 1, 2008 Share Posted January 1, 2008 hi peter....had a look for the wire colours so you can do it the hard way...the pin numbers will be stamped on the relay base. K and KE jetronic are the same apart from pin 15. Pin Wire 1 Green/Red 15 Black x 2 (1 maybe green/black tho) 87 Black/Red x 2 30 Red 31 Brown the contact that makes the pump run is between 30 and 87. good luck in finding it....I would have been looking for a pink one as well tho Link to comment Share on other sites More sharing options...
Guest peterw1983 Posted January 1, 2008 Share Posted January 1, 2008 i have found it i think it was the red one on my car cheeers everyone Link to comment Share on other sites More sharing options...
Guest steelcabby Posted January 1, 2008 Share Posted January 1, 2008 hello mate just had enougher look there is definetly not a pink one under there that i can see and i have been right under there the car i have put down as 1990 is actually a 1989 g reg xr3i cabriolet will that make any difference there is one green with nothing in one yellow with a yellow relay one blue with blue relay one red with red relay and a grey with grey relay black with yellow relay and black with green relay it dosen't matter if its 1990 or 1989, the feul pump relay is normally plugged into a pinky purple plug the relay is a pink one if its a genuine ford one. or it could be a black one if its a after market one. i have never know a mk4 not too have these plugs etc. it must be there. check the relay and see if any of them say fuel pump relay on them too. TBH there is a lot of wiring up there and the wires can get hooked up out of sight. i know its back and neck breaking but lot again hi peter....had a look for the wire colours so you can do it the hard way...the pin numbers will be stamped on the relay base. K and KE jetronic are the same apart from pin 15. Pin Wire 1 Green/Red 15 Black x 2 (1 maybe green/black tho) 87 Black/Red x 2 30 Red 31 Brown the contact that makes the pump run is between 30 and 87. good luck in finding it....I would have been looking for a pink one as well tho I've never known them not to have a pink plug etc, this would be the first. Link to comment Share on other sites More sharing options...
Guest steelcabby Posted January 1, 2008 Share Posted January 1, 2008 i have found it i think it was the red one on my car cheeers everyone disregard my last post then as i was writing it as you replied....pmsl.. well done mate. Link to comment Share on other sites More sharing options...
Guest peterw1983 Posted January 1, 2008 Share Posted January 1, 2008 THINK I MIGHT BE TAKING A TRIP DOWN THE FORD GARAGE TOMMOROW GET THEM TO HAVE ALOOK AS I BUGGERED IF I CAN SEE IT WILL LET YOU NO WHAT THEY SAY THANKS ALOT PETE Link to comment Share on other sites More sharing options...
Guest sjc Posted January 1, 2008 Share Posted January 1, 2008 well done peter.....yuo sure its not a light red pmsl do an ebay search for the relay....there are generally a few on there wiv piccies so you can see how pink they usually are Link to comment Share on other sites More sharing options...
